Warning message
pix 501 frequent disconnect vpn with vpn concentrator
May 17th, 2006
I have PIX 501 connect to vpn3030, on vpn3030, I got error message:
May 11 05:29:52 [10.18.80.10.2.2] 86222483 05/11/2006 05:37:07.100 SEV=4 AUTH/23 RPT=94052 x.x.x.x User [x.x.x.x] Group [x.x.x.x] disconnected: duration: 25:16:18
May 11 05:29:52 [10.18.80.10.2.2] 86222484 05/11/2006 05:37:07.100 SEV=4 AUTH/85 RPT=93396 LAN-to-LAN tunnel to headend device x.x.x.x disconnected: duration: 25:16:18
May 11 05:30:10 [10.18.80.10.2.2] 86222876 05/11/2006 05:37:25.450 SEV=4 AUTH/22 RPT=104541 x.x.x.x User [x.x.x.x] Group [x.x.x.x] connected, Session Type: IPSec/LAN-to-LAN
May 11 05:30:10 [10.18.80.10.2.2] 86222878 05/11/2006 05:37:25.450 SEV=4 AUTH/84 RPT=94969 LAN-to-LAN tunnel to headend device x.x.x.x connected
May 11 14:23:11 [10.18.80.10.2.2] 86659213 05/11/2006 14:30:27.120 SEV=4 AUTH/23 RPT=94055 x.x.x.x User [x.x.x.x] Group [x.x.x.x] disconnected: duration: 8:53:01
May 11 14:23:11 [10.18.80.10.2.2] 86659215 05/11/2006 14:30:27.120 SEV=4 AUTH/85 RPT=93399 LAN-to-LAN tunnel to headend device x.x.x.x disconnected: duration: 8:53:01
May 11 14:25:27 [10.18.80.10.2.2] 86662432 05/11/2006 14:32:43.080 SEV=4 AUTH/22 RPT=104587 x.x.x.x User [x.x.x.x] Group [x.x.x.x] connected, Session Type: IPSec/LAN-to-LAN
May 11 14:25:27 [10.18.80.10.2.2] 86662434 05/11/2006 14:32:43.080 SEV=4 AUTH/84 RPT=94976 LAN-to-LAN tunnel to headend device x.x.x.x connected
May 11 23:02:20 [10.18.80.10.2.2] 87064180 05/11/2006 23:09:36.140 SEV=4 AUTH/23 RPT=94064 x.x.x.x User [x.x.x.x] Group [x.x.x.x] disconnected: duration: 8:36:54
Fernando_Meza Wed, 05/17/2006 - 16:09
  • Gold, 750 points or more
Have you checked with the ISP in case the link is actually flapping ..?
Can you post the config of your PIX to have a look at ..?
