Warning message
Callmanager Hanging
May 17th, 2006
Folks,
I just built a callmanager cluster with 1 pub and 1 sub. I am running 4.1(3)SR3.
When i try to run the voicemail port wizard it hangs at Validating....
Also some menus are very slow to load.
DLLHost.exe is taking a lot of memory.
The CD's for callmanager were downloaded from my ftp server as i fotgot not get them with me on site.
Any thoughts?
gpulos Wed, 05/17/2006 - 12:48
  • Blue, 1500 points or more
dllhost.exe is a rather memory hungry process. this is probably normal.
what version of MCS? how much memory in server? what version win-OS-upgrade-K9??
how much disk space free/used on C: and any DB drives?
kurtdeneef Fri, 05/19/2006 - 06:04
I'm facing the same problem without the VM wizard thing :)
I regularly have CPU peaks and DLLHOST.EXE is always consuming the biggest part of the CPU at that time.
To answer your question
We are talking about the publisher which is a MCS-7800 with 1Gb of RAM but 1,6 GB is used (paged memory included)
I will reboot the CCM this evening,maybe we are dealing with a memory leak.
Kurt
jbarcena Wed, 05/17/2006 - 13:43
  • Red, 2250 points or more
Are you sure that you have SR3? There is a bug for SR3a about the VM port wizard hanging at Validating --> CSCsd59949
Workaround:
Replace the "newnumplaninfo.asp" file with one from 4.1(3) server.
C:\ciscowebs\Admin\wizards\voicemailports
newnumplaninfo.asp diffs between 4.1(3) system that works on 4.1(3)sr3a system that fails.
4.1(3) - works fine
function goNext()
if (flgValidateDNRangeInProcess)
flgUpdateDirectoryNumberWaiting = true;
return;
uOneWizard.submit();
function initPage()
4.1(3)sr3a - failure
function goNext()
else if (validate(document.uOneWizard))
function initPage()
