CAR and VPN
infomil
I try to implement CAR for limiting bandwidth used by specific trafic under an IPSec Tunnel between 2 878 routers over SDSL.
I specify access-list and use the rate-limit command under the dialer 1 interface.
The problem is that the dialer 1 interface has also the crypto map command and I think that the rate-limit command cannot work because the trafic is already encrypt when the rate-limit command is apply.
Is there an issue to my problem ???
Thanks.
mheusinger
Level 10
Level 10
you should have a look at the qos pre-classify feature. Basically the router "remembers" the original - unencrypted - header and can match based on this info. Unfortunately this is not supported by CAR, afaik. You would have to use class-based shaping, which is the better option anyhow IMHO.
An example config could be something like:
ip cef
class-map match-all Limit1
match ip address 101
class-map match-all Limit2
match protocol ftp
policy-map RateLimit
class Limit1
shape average 100000
class Limit2
shape average 64000
crypto-map MySec
qos pre-classify
interface Dialer1
service-policy output RateLimit
access-list 101 permit tcp 10.1.1.0 0.0.0.255 any eq 80
For further reading I would recommend you "Configuring QoS for Virtual Private Networks"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d3.html
Hope this helps! Please rate all posts.
Regards, Martin
