Two static routes in PIX.
May 18th, 2006
Hi gurus!
I wander if someone can tell me answer my question.
I have a PIX ver.6.3(4). I have one static entry to 142.x.x.x destination with AD=1 by default. When I add the second static entry to the same destination but with higher AD=50, the show route | i 142.x.x.x reveals only the preferable path.
Is it a normal behaviour?
amit-singh Thu, 05/18/2006 - 09:51
  • Blue, 1500 points or more
Hi Niggy.
When u do a show config, do you that route in there. If yes, then its the normal behaviour. If you dont see the route in there that means its not saving the changes or not updating the config.
HTH,
-amit singh
