Warning message
7970 display wrong time
i have a CCM 4.1(3) and only the ip phones 7970 and IP Communicator shows an incorrect time in screen, i've tried to change the time zone in windows in both (pub/subs), and reset the devices but nothing happens. The rest of the phones (7912/7940/7960) shows the right time.
Anyone could help me? could be some kind of bug? i need a new firmware?
Thanx in advance
Rodrigo
gogasca Thu, 05/18/2006 - 14:02
  • Green, 3000 points or more
Can you set up a specific Date/Group and Device Pool that Just the 7970 uses, so that the 7970's have a specific Device Pool that uses a specific
Date/Time group and then does the 7970 display the correct time ?
I would upgrade to latest firmware and IPC 2.0.1
(Try one if that helps)
Actualy WE DO have open a DDTS for this one, but dont have it handy.
gpulos Thu, 05/18/2006 - 14:45
  • Blue, 1500 points or more
i've seen this behavior in load 7.2(2) and 7.2(3).
i've upgraded to 8.0(2) SR1 and problem is fixed! :)
try this load if you can.
jbarcena Fri, 05/19/2006 - 11:54
  • Red, 2250 points or more
Gogasca is right, there are several bugs about this issue, some of them are CSCec75767:
Symptom:
The time on the IP Communicator phone is incorrect. The time displayed is GMT instead of local time zone.
Problem:
If the CM Date/Time group uses 'local time zone of CallManger' instead of explicit time zone setting, the IP Communicator will display the time in GMT.
Workaround:
Explictily set the time zone setting to the local time zone
CSCed84371:
Symptom:
When Mountain Time Zone (US & Canada) was selected , 7970 phone, shows
7 hours ahead of the actual time that should be. If Eastern time or central time is selected on
7970 phone, it show the correct time.
Conditions:
When Mountain Time zone is used.
Workaround:
None.
Pretty much all of them are fixed in the latest firmwares, so follow Gonzalo's suggestions.
