%ONLINE-SP-6-TIMER on CSG insertion
May 19th, 2006
Hi all,
I am experiencing an issue with CSG card.
I'm trying to install it into a Catalyst 6500 with Sup720 running IOS 12.2(18)SXE5 but without success.
I don't know CSG actual release because I haven't other Catalyst on which testing it.
The error that I receive repeatedly on console is:
00:05:15: %ONLINE-SP-6-TIMER: Module 6, Proc. 0. Failed to bring online because of timer event
00:05:15: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Module Failed SCP dnld)
00:06:55: %ONLINE-SP-6-TIMER: Module 6, Proc. 0. Failed to bring online because of timer event
00:06:55: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Module Failed SCP dnld)
00:08:35: %ONLINE-SP-6-TIMER: Module 6, Proc. 0. Failed to bring online because of timer event
00:08:35: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Module Failed SCP dnld)
and the module remains in Power Down state with no possibility of reset:
Beta#hw-module module 6 reset
Proceed with reload of module?[confirm]
% module 6 is operationally off (Module Failed SCP dnld)
I looked for this error on CCO and it seems that the Catalyst itself should solve the problem, but it doen't happen.
I also tried to move CSG to other slots bur the result is still the same.
Does anyone know what is the cause of this behavior and how can I fix it?
Thanks a lot
Chiara
fmeetz Thu, 05/25/2006 - 05:59
  • Bronze, 100 points or more
you have to get the card replaced.
