Warning message
7960G IP phone switchports and BPDU-guard compatibility
Answered Question
May 19th, 2006
The 7960 IP phone has an "internal two-port Ethernet switch allows for a direct connection to a 10/100BASE-T Ethernet network via an RJ-45 interface with single LAN connectivity for both the phone and a co-located PC" per Cisco. Does the fact that this is a switch propagating multiple MAC addresses to my 6509's switchport pose an issue if I'm running BPDU-guard on it ? Don't these "internal switches" on the phones send BPDUs?
Correct Answer by Aaron Harrison about 11 years 3 months ago
It'll work fine - the phones have a 'switch' but don't produce BPDUs or participate in STP.
Aaron
please rate helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Fri, 05/19/2006 - 08:51
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
amit-singh Fri, 05/19/2006 - 09:19
  • Blue, 1500 points or more
Hi Friend,
No, the IP phones doesnt send any BPDU's. This will not pose any issues.
HTH, Please rate if it does.
-amit singh
