Warning message
IOS UPDATE
Hi ankur 10xs for ur reply
sir;if i use this command:
copy tftp flash
Address or name of remote host [255.255.255.255]? 10.10.10.10
Source file name?c3560-ipservicesk9-mz.122-25.SEB4.bin
Destination file name? c3560-ipservicesk9-mz.122-25.SEB4.bin
Erase flash device before writing? [confirm] yes/no/yes
this command work or not?
10xs for ur reply
ali
ankurbhasin Sat, 05/20/2006 - 23:43
  • Red, 2250 points or more
Hi Ali,
I am not very sure about the copy command but looking at the documents (config guide and command reference for 3560) copy command is not present anywhere.I checked one of the very old ios for 3560 which is 12.1(19)EA1, February 2004 and this release also does no sow the copy commands in their documents and stressed on "archieve" command
Have a look at this link for 3560 config guide "Working with IOS file system"
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12119ea1/3560scg/swiosfs.htm#1020620
But being an IOS based switch this command should be present there but not sure if that command will work or not but no harm in trying copy command, you can try that command if it is available in IOS.
HTH, if yes please rate the post.
Ankur
