Warning message
831 SDM router config upload
Answered Question
May 22nd, 2006
Hi everyone!
I have multiple routers to set up with pretty much the same configuration. I'd like to save the configuration file and upload to another router.
IOS: 12.4(4)T1
SDM: 2.2
Correct Answer by corey.mckinney about 11 years 3 months ago
You can use a TFTP Server application to copy it to your PC, and then copy it to each router. The commands are as follows:
'copy start tftp' - Copies from router to PC.
'copy tftp start' - Copies from PC to router.
You can download a free TFTP server at the following link:
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
Hope this helps!
Overall Rating: 5 (1 ratings)
Correct Answer
corey.mckinney Mon, 05/22/2006 - 13:27
Hope this helps!
