Warning message
counters not cleared in the clear counter command
May 23rd, 2006
May I know is there any counters in the "sh interface" that will not be cleared by the clear counter command ? I think "total output drop" is one. Can anyone verify ? good if anyone can share any cisco doc that show this.
Overall Rating: 3.5 (2 ratings)
a.hajhamad Fri, 05/26/2006 - 02:12
  • Bronze, 100 points or more
The clear counters command clear ALL the interface counters.
Please see the attached file which lists the show interface command and after the clear command issued, you can see the output show interface command, all the interface counters are cleared.
IOS clear counters command...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tir_r/int_a1ht.htm#wp1199810
Please rate if it does!
Abd Alqader
