snmp alerts for CPU utilization
May 23rd, 2006
I want to enable snmp alerts on l2 and l3 switches to monitor CPU utilization.
I have Opmanager which is acting as SNMP server.
I have switches L2 and L3 which are running IOS 12.0, 12.1, 12.2
Do all these IOS versions support SNMP alerts?
And also I want to know the commands to be configured on switches for this.
skrao
Overall Rating: 4 (1 ratings)
phil.davenport Fri, 05/26/2006 - 03:17
You can configure SNMP traps for CPU Thresholding Notification.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455772.html
You should be ok with the versions you list but check exact IOS version supports it at http://www.cisco.com/go/fn
If you do not want to use traps then there are specific oids that can be polled for 1minute average (1.3.6.1.4.1.9.2.1.57) and also 5 minute average (1.3.6.1.4.1.9.2.1.58). I've used these in the past with no problems. These oids may have been superceeded so check for latest. You can always snmpwalk a device to check oids.
The cisco SNMP navigator is helpful when it comes to oids.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
If you haven't got any SNMP configured yet on the switch check out http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddb4e54
--Phil
