pix 501, Interface 0 protocol Down..
May 23rd, 2006
The router is connected to port 0 of the firewall, but there is no led shown on port 0 of the firewall, seems like there is no connectivity, I already write erase the config but still no luck..
Here is show interface 0,
interface ethernet0 "outside" is up, line protocol is down
Hardware is i82559 ethernet, address is 0012.0087.958f
MTU 1500 bytes, BW 10000 Kbit half duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9 packets output, 5310 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
9 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/0)
output queue (curr/max blocks): hardware (0/1) software (0/1)
Could it be a hardware failure?
Thanks...
Fernando_Meza Tue, 05/23/2006 - 19:09
  • Gold, 750 points or more
hi ..try using a cross over cable !!!
Also make sure speed and duplex match in both ends.
I hope it helps ... please rate it if it does !!!
akorolkov Tue, 05/23/2006 - 19:33
Do you have 100/half duplex configured on purpose?
It could be you have duplex or speed mismatch, check it and if required hard code it.
tonny_ecmyy Tue, 05/23/2006 - 20:07
the pix is running fine before, I've using it 1 yr +,
I'm afraid the port 0 is deffective
Is there any command that cause the pix interface to shutdown? Like the cisco router by issuing no shutdown?
akorolkov Tue, 05/23/2006 - 20:24
conf t
interface ethernet0 shut
interface ethernet0
tonny_ecmyy Tue, 05/23/2006 - 21:32
interface ethernet0 "outside" is administratively down, line protocol is down
I can't administratively up it even after doing this command:
interface ethernet0
How do i up it again...?
Thanks for helping...
a.kiprawih Tue, 05/23/2006 - 21:52
Hi Tony,
It's a hardware issue - faulty interface.
At any time, if the interface is operational, even when you do not connect it to any device, the interface status should be 'up' all the time. Only the line protocol maybe down.
If you shut it down, the status clearly tells you administratively shut down. But when it says interface is down, it was a physical interface problem (could be anything internally). You probably need to send it for RMA or get new box. I don't think recovery can fix it.
Rgds,
AK
tonny_ecmyy Tue, 05/23/2006 - 22:10
Ohh man... that was i suspect earlier, i have another pix 506, when i type interface ethernet0 shut, yes its down and can be up again after typing interface ethernet0... but this pix501, its forever down... never up again after typing interface ethernet0 shut, today is the last action of my pix501... any way, can it be repair?
a.kiprawih Tue, 05/23/2006 - 22:58
Hi Tony,
I am not sure if it can be repaired, but personally, I don't think so. Both Outside (e0) and inside (e1) are integrated ports. You can do that (replace) only for extra/additional Ethernet cards for 515E/525/535.
You have to get new box, maybe from your vendor, or if it is still under warranty, get replacement unit.
Hope this helps.
Rgds,
AK
