Warning message
IP IVR 2.1(1a) upgrade to IP IVR 3.5(3)
May 24th, 2006
One customer wants to upgrade IP IVR 2.1(1a) to 3.5(3). This version is old and I can not find any upgrade document I can reference. And Customer wants to keep his DB. I think it is very diffcult to me. What about the step?
Yi Cai
adignan Wed, 05/24/2006 - 20:58
  • Blue, 1500 points or more
I would suggest saving your scripts off box, take screen shots of your ip ivr configuration pages, and rebuild completely.
This is your "safest" option.
If you don't want to go that route you can upgrade to 3.5 and then run the repository conversion and the procedure is here:
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_installation_guide_chapter09186a0080155ae8.html
please rate helpful posts.
adignan - berbee
classical_006 Wed, 05/24/2006 - 22:52
Thanks! But what about the license? Can License for IP IVR 2.0 use in IP IVR 3.5?
