Warning message
7204 cpu maxed out
May 24th, 2006
HI all,
Lately my 7204 vxr router has been going crazy on me. I have noticed that from time to time, the cup usage jumps to 99%. Now what I have been doing is clearing the IP NAT translations that it is doing and that seems to fix that problem.
Now is this a bug in the IOS or is it simply a memory problem that I can fix by getting more.
spremkumar Mon, 05/29/2006 - 23:05
  • Red, 2250 points or more
can you post the output of show version taken from your router so tht it can be verified for possible bugs and suggest for a suitable upgrade ..
Also any logs available in your router pertaining to this hike in ur cpu ?
regds
c.mac Tue, 05/30/2006 - 06:48
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(11)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 02-Aug-02 10:51 by ccai
Image text-base: 0x60008940, data-base: 0x61850000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE
JEH7204 uptime is 1 day, 16 hours, 24 minutes
System image file is "disk0:c7200-is-mz.122-11.T.bin"
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 23658225
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
20 Serial network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Could be an IOS bug or a memory leak due to the config. You might also need to shorten the timeout values on some of the connections. Try using this to shorten the output of your "sh proc cpu":
alias exec ps show proc cpu | excl 0.00%__0.00%__0.00%
This will drop anything reading 0.00% and leave you with what you were looking for in the first place. Hope this helps.
