Not able to change auto to trunk mode on switch
glen.grant Wed, 05/24/2006 - 15:30
  • Purple, 4500 points or more
You have to specifically set the encapsulation type first "switchport encapsulation dot1q" then try youir command...
glen.grant Wed, 05/24/2006 - 16:32
You need to specifically set the encapsulation first , "switchport encapsulation dot1q" then issue your trunk command...
glen.grant Wed, 05/24/2006 - 16:36
can you post the config...
ankurbhasin Wed, 05/24/2006 - 22:00
  • Red, 2250 points or more
Hi All,
The command which he need to enter first is
"switchport trunk encapsulation dot1q " and then he can confgigure the interface in trunk mode.
So try this command
switch(config)#interface fa0/1
switch(config-if)#switchport trunk encapsulation dot1q
switch(config-if)#switchport mode trunk
and you will be good to go.
HTH, if yes please rate the post.
Ankur
ankurbhasin Fri, 05/26/2006 - 00:31
Hi Friend,
Thats not required because if you put the config which I posted in my previous mail it will take care of the issue.
Ankur
FatimaBeyelhadj Wed, 10/02/2013 - 09:28
This worked on one of the switches and not the other?!
What do you think could be the cause besides lab technical issues?
Serge Amos Wed, 10/09/2013 - 05:39
Could you run a " sh int gig #/# capabilities"
look under Trunk encap. type:
and Trunk mode:
it will give you capabilities information of the port
zul qarnain Fri, 06/13/2014 - 17:14
Hi Ankur,
I have question why for switch multilayer is different from switch not multilayer if we need configure trunk on port?
suyash.ag92 Tue, 12/06/2016 - 01:20
switchport trunk encapsulation dot1q is not working.  After switchport trunk its not accepting encapsulation
randdavis Tue, 07/12/2016 - 16:22
Thanks your guidance worked great and now my ports are trunking.
