Warning message
Use OpenPhone with CVP
May 25th, 2006
Anyone knows how to use OpenPhone with CVP? What do I need to set in OpenPhone's address field and gateway field when making a call? Is it the VXML gateway IP or gatekeeper IP?
Thanks.
I haven't fully tested compatibility with CCM, so YMMV. But if it is a comprehensive mode deployment, configure the gatekeeper option in OpenPhone.
Options/Gatekeeper/Static Host
If it is not, you would point to the IP of the Voice Browser in the address field you refer to.
HTH,
Michael
