Downloadable ACLs on IOS Routers
May 27th, 2006
I am using an aysnchronous interface on a router for dialup connections. I am using CSACS RADIUS for user authentication and authorization. I have also configured downloadable IP ACL's on the CSACS server. A packet capture shows that the ACS server is notifying the router about the ACL but the router is not requesting the ACL. Is it even supported in IOS? I'm not so sure.
I have successfully configured this on my 3000 series VPN concentrators but am having difficulty getting the router to play nice. I suspect I am missing something on my router configuration but don't see what it could be.
A sample config on the router or a link to a site that explains it will be greatly appreciated. Thanks in advance..
itdojo Sat, 05/27/2006 - 08:13
The ACS user guide says they are supported on 12.3(8)T and greater. This may be my problem. I will try an different IOS and let everyone know how it goes.
