LMS 2.5 and HP OV NNM 7.5 integration
May 29th, 2006
Hi, collegues! I have the following problem.
I have CW LMS 2.5 installed on Windows and HP OV NNM installed in Solaris server. I need to integrate them. After integration I try to launch CW-applications from the NNM map and get the message "Access Forbidden".
What may be the reason of it?
David Stanford Mon, 05/29/2006 - 08:34
  • Cisco Employee,
Are there any error messages in NNMAdapter.log?
Did you stop ov and do ovtopofix after the integration was run?
jromanov Mon, 05/29/2006 - 22:13
I didn't see any problems during installing adapter on NNM. The installation was successful. It seems to me that problem is caused of CW part.
The NNM is installed on Solaris and CW - on Windows system. I used Integration Utility 1.6! Is it possible to be the cause of problem?
