Bandwidth limit to the customers
May 30th, 2006
Dear All,
Good day to you all.
I setup a samll LAN to one of my customer. The LAN consists of the following
1. Cisco catalyst WS-C2950-24SX- 01
2. ADSL Alcatel speedtouch router 128/64
for the Internet connection. ISP provides this device .
3. 5 hp PCS
Now the customer wants to limit the Internet bandwidth to each customers so that every one use 20 MB for both upload and download if more than that access the connection should be terminated.
How can I do it wth Cisco features?
Please help me.
thanks
swamy
Overall Rating: 4 (2 ratings)
gpulos Tue, 05/30/2006 - 07:59
  • Blue, 1500 points or more
it doesn't look like your DSL connection could handle 20MB total, let alone 20MB from 5 users simultaneously.
how fast if your DSL up/down?
also, the 2950 can perform storm-control (bandwidth based only; uses % of bandwidth)
switch# interface f0/1
switch-interface# storm-control unicast level 20 15
switch-interface# storm-control action shutdown
the above will provide a bandwidth limit for the port to receive traffic. if the bandwidth is => 20% then the port gets shutdown. if the bandwidth falls below 15% then the port is set to forward packets again.
perhaps storm-control for unicast packets can be used in this case:
or perhaps you can set your PCs to 10/full or check if the NICs have any capabilities.
arumugasamy Wed, 05/31/2006 - 23:00
Mr.Gpulos,
First I would you for your info.
Here the 20 MB is the LAN bandwidth to be limited to the per user basis. I will try it to update you.
Also Pls let me know about the Netflow concept and where can we implement in the real networking scenarios.
Thanks in advance
swamy
