Warning message
Analog phone via built-in FXS ports?
May 30th, 2006
We currently have a Cisco CallManager Express implementataion with a 2811 router, 4 built-in FXS and 4 FXO ports, and (5) 7960 IP phones. We would like to use a standard cordless phone for manager only usage early in the morning.
We connected the phone to the first FXS port and are able to dial out and make calls properly as per the dial-peers that are already configured. We would like to configure this FXS port so this analog phone could function similar to an IP phone (answering incoming calls, possibly transfer and on-hold functions).
I've read the CCME admin guide and the guide on voice ports, but I'm having trouble with the solution. I understand that it needs to be configured as an ephone, but how do I configure the ephone to point to the FXS port? Or am I way off base?
Thanks in advance!
Aaron Harrison Tue, 05/30/2006 - 22:47
  • Community Spotlight Award,
    Member's Choice, May 2015
You don't need to create an ephone - the internal voice ports are real ports so don't need the virtual construct.
All you need to do is configure the voice-port that is already in your config appropriately, then create a dial-peer x pots to point at it... e.g:
voice-port 0/0
cptone GB
dial-peer voice 1 pots
destination-pattern 1234
port 0/0
This should get basic calling in working...
Aaron
Please rate helpful posts
aceprecision-jasonl Wed, 05/31/2006 - 06:42
Maybe I should clarify. This is a complete CME installed and working with 5 IP phones. People can call in and out with the IP phones, and everything works exactly like it should. I just want to give them the ability to use a cordless phone via the built in FXS port. If I plug in the analog phone to the FXS port, that phone can dial out according to the dial-peers already configured.
Now, I want to give them the ability to answer an incoming call. So basically, when a call comes in the FXO port, I want this analog phone connected to the FXS port to ring also...giving the user the ability to answer that phone if they aren't near an IP phone.
I hope that clears things up...Thanks for the help!
aceprecision-jasonl Wed, 05/31/2006 - 07:03
Here is a sanitized config from the router:
voice-port 0/0/0
supervisory disconnect anytone
connection plar opx 150
description FXO-xxx-xxx-xxxx
station-id name Outside Line
voice-port 0/0/1
connection plar opx 151
voice-port 0/0/2
connection plar opx 152
voice-port 0/0/3
description FXO-Unused
voice-port 0/1/0
description Cordless Phone
station-id name Cordless Phone
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer voice 201 pots
preference 3
destination-pattern 91..........
port 0/0/1
forward-digits 11
dial-peer voice 202 pots
preference 2
port 0/0/2
forward-digits 11
dial-peer voice 200 pots
preference 4
port 0/0/0
forward-digits 11
dial-peer voice 100 pots
preference 4
destination-pattern 9[2-9]......
port 0/0/0
forward-digits 7
dial-peer voice 101 pots
preference 3
port 0/0/1
forward-digits 7
dial-peer voice 102 pots
preference 2
port 0/0/2
forward-digits 7
dial-peer voice 300 pots
preference 4
destination-pattern 9T
port 0/0/0
dial-peer voice 301 pots
preference 3
port 0/0/1
dial-peer voice 302 pots
preference 2
port 0/0/2
dial-peer voice 400 pots
description Local FAX on router
destination-pattern 160
port 0/1/0
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000600
max-ephones 36
max-dn 144
ip source-address 192.168.10.254 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
moh music-on-hold-1.wav
multicast moh 239.1.1.1 port 2000 route 192.168.10.254
transfer-system full-consult
secondary-dialtone 9
ephone-dn 1
number 150
label Line-1
description Outside Line 1
hold-alert 30 shared
ephone-dn 2
number 151
label Line-2
ephone-dn 3
number 152
label Line-3
ephone-dn 100
number 100
label location0 100
description xxx-xxx-xxxx
name Office
ephone-dn 101
number 101
label location1 101
name location1
ephone-dn 102
number 102
label location2 102
name location2
ephone-dn 103
number 103
label location3 103
name location3
ephone-dn 104
number 104
label location4 104
name location4
ephone-dn 105
number 105
label location5 105
name location5
ephone 1
mac-address xxxx.xxxx.xxxx
type 7960
button 1:100 2:1 3:2 4:3
ephone 2
type 7960
button 1:101 2:1 3:2 4:3
ephone 3
type 7960
button 1:102 2:1 3:2 4:3
ephone 4
type 7960
button 1:103 2:1 3:2 4:3
ephone 5
type 7960
button 1:104 2:1 3:2 4:3
ephone 6
type 7960
button 1:105 2:1 3:2 4:3
