Warning message
managing switch
May 30th, 2006
Hi! i am new to cisco and wnat to know one thing.....how can we manage switch from web interface....and which switches can be managed from web....i have 1924 and 2950 switch i have the console cable but dont know how to do it through web.....do i have to install something....plz help me out ....thanks in advance
aazim Sat, 06/03/2006 - 06:56
In addition to Cisco Network Assistant which is a Windows based application, the 2950 switch also comes with an embedded device manager. All you need is to type the IP address of the 2950 switch in the browser to access it. Please note that the embedded device manager comes with the .tar images so if you have only been using .bin images to upgrade the switch then you will not get the device manager. If this is a brand new switch then by default it does come with the web device manager.
wang19841229 Sat, 06/03/2006 - 19:41
switch's config have ip http server is OK
2950 switch have a manage IP .IN IE import switch's manage IP
I am chinese so my English is not good.
