Warning message
access list in pix 506
May 30th, 2006
I am using pix 506, and one of our user wants to connect to yahoo messanger,
can any one help me on how enable yahoo port thru. pdm program.
Thank you all for yourhelp.
Ahmad
Overall Rating: 5 (1 ratings)
Fernando_Meza Tue, 05/30/2006 - 22:14
  • Gold, 750 points or more
There are actually several ports you will need to open some for outbound and some for inbound. I suggest you open the outbound ( client ) only.
nat (inside) 1 access-list Inside_Out
global (outside) 1 interface
access-list Inside_Out permit tcp host any eq 5050
access-list Inside_Out permit tcp host any eq 80
access-list Inside_Out permit tcp host any eq 5100
access-list Inside_Out permit tcp host range 5000 5001
access-list Inside_Out permit udp host range 5000 5010
NOTE: if you have an access-list aplpied to teh inside interface then you need to modify that access list accordingly.
I hope it helps .. please rate it if it does !!!
Ports Yahoo! Messenger uses!
Yahoo! Messenger services uses a variety of ports.
Service Ports
Chat & Messenger TCP Port 5050: Client Access only
Insider/Room Lists TCP Port 80: Client Access only
File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer.
Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below.
WebCam TCP Port 5100: Client Access
Super Webcam TCP Port 5100: Server Access
P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
