Voicemail cuts off after about 5 seconds
Answered Question
May 31st, 2006
  • Blue, 1500 points or more
I have a site that if someone calls from outside and tries to leave a voicemail it get cut off after about 5 seconds and the person calling does not know this has happened. If I call them from another one of our offices from a VoIP phone it works fine.
Ideas?
Mike
Correct Answer by Brandon Buffin about 11 years 2 months ago
Mike,
I'm assuming your voicemail is Unity. Is it integrated with Callmanager or some other system? Take a look at the following link for some troubleshooting tips for this problem.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_troubleshooting_guide_chapter09186a0080449d92.html#wp1144479
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 05/31/2006 - 12:50
  • Purple, 4500 points or more
Mike,
Brandon
burleyman Thu, 06/01/2006 - 09:55
Thanks that did help. It was the time setting and a routing issues as well.
Thank you,
Mike
Chris Deren Wed, 05/31/2006 - 12:51
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Is the first 5 seconds actually being recorded?
Chris
burleyman Thu, 06/01/2006 - 09:57
Yes it was. It turned out to be a timing and routing issue.
Mike
