Warning message
Combining DCD Directories from 2 CCM Clusters
Jun 1st, 2006
I am looking for anyone who has successfully combined 2 CCM DCD directories. This could have been accomplished with XML or some other script. I know that the option to migrate to AD and use the AD plugin exists but that is not an option for us at this time. Any advice would be welcomed.
Overall Rating: 4 (1 ratings)
gogasca Fri, 06/02/2006 - 06:11
  • Green, 3000 points or more
hi pranayama
I have never tested it and dont know fo any of our customers which has that setup.
But u can gve it a try configuring Directoryconfiguration.ini, UMDirectoryconfiguration.ini and regedit.
I mean this files are used for Any directory Integration. So u may copy those files from Cluster A to lets say to cluster B (backup first) and give it a try not sure if it will work.
If Jorge see this post he may try in our lab.
