Warning message
Why is my static doing this?
Jun 1st, 2006
Hi- hope someone can help with this one.
I've a PIX501, with a fairly basic config: patting an RFC1918 network on a single public IP (PIX's outside interface), PIX is a PPTP server with local authentication, and, up until now, any traffic has originated on the inside and is headed outbound.
Anyway: I now want to forward https (443 on tcp) into my network, to allow Microsoft webmail into one of my servers, on 192.168.2. Fairly straightforward, you would think...
So, I add the following 3 lines:
-access-list webmail_in permit tcp any host (PIX-EXTERNAL-IP-ADDRESS) eq https
-access-group webmail_in in interface outside
-static (inside,outside) interface 192.168.1.2 netmask 255.255.255.255 0 0
However- after I add the static in, oddly, this then knocks out internet access to my other LAN clients- apart from the server on 192.168.1.2!
I'm really stuck on this one.
Anyway, if anyone cares to delve in, here's my sanitised config:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password (changed) encrypted
passwd (changed) encrypted
hostname (changed)
domain-name (changed)
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 192.168.1.0 255.255.255.0
pager lines 100
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside (PIX-EXTERNAL-IP-ADDRESS)
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 192.168.1.100-192.168.1.150
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 (NEXT HOP) 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community dascapito
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
console timeout 0
vpdn group pptp-vpn accept dialin pptp
vpdn group pptp-vpn ppp authentication mschap
vpdn group pptp-vpn ppp encryption mppe auto
vpdn group pptp-vpn client configuration address local vpnpool
vpdn group pptp-vpn client configuration dns 192.168.1.2
vpdn group pptp-vpn client configuration wins 192.168.1.2
vpdn group pptp-vpn pptp echo 60
vpdn group pptp-vpn client authentication local
vpdn username (username) password (password)
vpdn enable outside
terminal width 80
TIA-
Gary
cpembleton Thu, 06/01/2006 - 11:36
  • Silver, 250 points or more
Your config is a little off. You have only 1 external ip address so if you static that address to 1 internal host all other host won't have and addres to translate. The static needs to have the tcp port translation. Try the following
static (inside,outside) tcp interface 443 192.168.1.2 443 netmask 255.255.255.255 0 0
access-list webmail_in permit tcp any interface outside eq 443
http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aad.shtml#topic9
Chad
0r8it Thu, 06/01/2006 - 13:02
Chad, thanks a lot. I had assumed that the acl would cover what the static would translate, port-wise. I will try this out.
Cheers-
Gary
