CEF on Multilink GRE tunnels
Jun 2nd, 2006
Can I use CEF on 1811 router. There will be 2 cable internet connections with an 1811 router on both ends. I want to establish site to site VPN and per packet load balance both connections on both ends.
istadmin1 Fri, 06/02/2006 - 08:55
Do you know specifically if this can be done using the pair of built in ETHERNET WAN ports on the 1811? I have gotten a lot of confusion over this as most people use some form of serial WIC interface when load balancing on routers. Please also see attached diagram. Thank you for the responce.
