Warning message
HELP required !!!
Jun 2nd, 2006
I want to know wheather I can make and receive SIP calls. My Router Configuration is as follows:
Router - 1751
IOS Image Name: c1700-sv8y7-mz.123-2T9.bin
IOS Version: 12.3(2)T9
Feature Sets: IP (Internet Protocol)
Hardware Details
Model Type: Cisco 1751
Total Memory: 64 MB
Total Flash Capacity: 16 MB
Boot From: flash
Hardware Configuration
Slot 0: C1751 Mainboard
#10/100Ethernet
#WIC Slot 0: 1 Port Ethernet (WIC-1ENET)
# WIC Slot 1: 2 Port FXS (VIC-2FXS)
# WIC Slot 2: 2 Port FXO (VIC-2FXO)
This Unit is installed in New Delhi. Broadband connection from MTNL New Delhi with Static IP Address.
I have SIP account with www.web.de in Germany. And I want to make and receive calls from Germany.
Please HELP!!!
gpulos Fri, 06/02/2006 - 03:09
  • Blue, 1500 points or more
the IOS should be upgraded to 12.3.7T12.
previous releases have been defered and you'll need the ip voice feature set.
this does require 96MB ram and 32MB flash though.
chopra Fri, 06/02/2006 - 04:19
As per my informations, upgrading of Flash in Cinsco 1751 is not possible.
Is there any other way, where I do not have to upgrade the memory.
tdrais Fri, 06/02/2006 - 09:39
You need to upgrade the ram which appear is possible.
You should be able to boot the router from a TFTP server. Not sure I would do this for a production router but i have done it many times in the lab.
how about my version? could an FXS or FXO card can work without upgrading the mem or IOS? Please see below
IOS (tm) C1700 Software (C1700-K8O3SY7-M), Version 12.2(8)T5, RELEASE SOFTWARE)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 21-Jun-02 19:24 by ccai
Image text-base: 0x80008108, data-base: 0x80D2EACC
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
cisco1751 uptime is 17 hours, 30 minutes
System image file is "flash:c1700-k8o3sy7-mz.122-8.T5.bin"
cisco 1751 (MPC860P) processor (revision 0x600) with 36864K/12288K bytes of mem.
Processor board ID JAD06390282 (3061614917), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
1 Virtual Private Network (VPN) Module(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Nicholas Matthews Sun, 01/18/2009 - 13:13
  • Red, 2250 points or more
You will not be able to use DSPs, voice cards, or voice protocols without a voice image.
For the 1700 you can identify a voice image if it has a 'v' in the IOS name.
hth,
nick
