How can I import Client data base from one concentrator to another
Jun 2nd, 2006
Can anybody out there give me some advice on how to transfer or import user data base from one concentrator to another?..........Thx..........
a.hajhamad Fri, 06/02/2006 - 14:08
  • Bronze, 100 points or more
If you mean that you need to replicate VPN concentrator to another, you need to do the following:
At the origional VPN conc. go to
Administration>File Management>
You will see two configuration files (config.bak (saved) and config (running configuration)), click view for any file and save it to your PC with TXT format.
At the destination conc. go to
Administration > File Management> File upload
at the "File on the VPN 3000 Concentrator" type config.bak and at the "Local File" browse your saved file. Afterthat, go to Administration > File Management > Swap config file. Now, the concentrator will be rebooted with the config.bak configuration.
I hope this is helpful!
Please rate if it does.
Abd Alqader
linhthasack Mon, 06/05/2006 - 08:11
Thanks for the reply.... but it is not quite what im looking for. I do not want the whole config. I just want the local user database itself copy to my backup concentrator.
a.hajhamad Thu, 06/08/2006 - 04:17
I don't thing that there is a way to backup a user database only, you can take the whole config and copy the user database from that file.
Abd Alqader
