OSPF on PIX
Jun 4th, 2006
We are running OSPF; we have PIX 525 protecting our server farm. OSPF process is running fine on PIX. PIX have established adjacencies with switches and routers on the same segment and show full neighbor relationships with all devices. All Interfaces belongs to same area, the advertising interface is outside, and it cannot be down because all traffic is going through. I am also attaching the config of PIX for your review.
These both networks are directly connected to the PIX on layer2.
router ospf 1
network 172.16.1.0 255.255.255.0 area 101
network 172.16.3.0 255.255.255.0 area 101
network 172.16.103.0 255.255.255.0 area 101
network 172.16.104.0 255.255.255.0 area 101
router-id 192.168.255.84
log-adj-changes
The problem is PIX is showing all the subnets in OSPF database received from other network devices, but no other network device is showing the IP subnets of server farms which are supposed to be advertised by PIX.
gopal_4476 Sun, 06/04/2006 - 23:23
Hi Umar,
Can you give clear picture about your network. For instance whether your server farm ip segment.
Regars,
Gopal
umar-rana Mon, 06/05/2006 - 01:44
The server farm IP class is 172.16.1 and 172.16.3.
172.16.103 is used to link the firewall with switches and 104 is for state full failover.
Output of show ospf nei command.
Neighbor ID Pri State Dead Time Address Interface
192.168.255.83 1 FULL/BDR 0:00:35 172.16.103.249 outside
192.168.255.82 1 FULL/DR 0:00:34 172.16.103.250 outside
Output of show run | inc adder
ip address ccsrv 172.16.1.252 255.255.255.0
ip address intf2 172.16.104.252 255.255.255.0
ip address inside 172.16.3.252 255.255.255.0
ip address outside 172.16.103.252 255.255.255.0
failover ip address ccsrv 172.16.1.251
failover ip address intf2 172.16.104.251
failover ip address inside 172.16.3.251
failover ip address outside 172.16.103.251
vladrac-ccna Mon, 06/05/2006 - 06:40
  • Silver, 250 points or more
I think you should check on the other devices configuration too.
You said that you dont see the routes on the other routers? Can you see it on the ospf database?
Let us know more about the other devices configs.
vlad
umar-rana Mon, 06/05/2006 - 22:40
Other devices configs are standard, I am pasting one of my core switches ospf config and output of show nei. The PIX is connected with two of these switches.
OSPF config:
router ospf 1
log-adjacency-changes
network 172.16.8.0 0.0.0.255 area 101
network 172.16.9.0 0.0.0.255 area 101
network 172.16.12.0 0.0.0.255 area 101
network 172.16.13.0 0.0.0.255 area 101
network 172.16.14.0 0.0.0.255 area 101
network 172.16.15.0 0.0.0.255 area 101
network 172.16.102.0 0.0.0.255 area 101
network 172.16.103.0 0.0.0.255 area 101
Sh ip ospf nei
192.168.255.83 1 FULL/BDR 00:00:35 172.16.9.249 Vlan2
192.168.255.83 1 FULL/BDR 00:00:35 172.16.12.249 Vlan3
192.168.255.83 1 FULL/BDR 00:00:33 172.16.13.249 Vlan4
192.168.255.83 1 FULL/BDR 00:00:33 172.16.14.249 Vlan5
192.168.255.83 1 FULL/BDR 00:00:32 172.16.15.253 Vlan6
192.168.255.83 1 FULL/BDR 00:00:32 172.16.8.249 Vlan8
192.168.255.81 1 FULL/DR 00:00:30 172.16.102.254 GigabitEthernet2/17
192.168.255.83 1 FULL/DROTHER 00:00:36 172.16.102.249 GigabitEthernet2/17
192.168.255.84 1 FULL/DROTHER 00:00:37 172.16.103.252 GigabitEthernet2/18
192.168.255.83 1 FULL/BDR 00:00:37 172.16.103.249 GigabitEthernet2/18
192.168.255.83 is a Core Switch connected with PIX
192.168.255.82 is also a Core switch connect with PIX
192.168.255.81 is Router acting as ABR
192,168.255.84 is PIX firewall
Show ip ospf database (on core switch)
Net Link States (Area 101)
Link ID ADV Router Age Seq# Checksum
172.16.8.250 192.168.255.82 439 0x800002AF 0x0014B3
172.16.9.250 192.168.255.82 439 0x800002AF 0x0009BD
172.16.12.250 192.168.255.82 439 0x800002AF 0x00E7DB
172.16.13.250 192.168.255.82 439 0x800002AF 0x00DCE5
172.16.14.250 192.168.255.82 439 0x800002AF 0x00D1EF
172.16.15.250 192.168.255.82 439 0x800002AF 0x00C6F9
172.16.102.254 192.168.255.81 581 0x800005E0 0x001A59
172.16.103.250 192.168.255.82 624 0x80000292 0x00CD33
