SBC T1 CAS Supertrunk shows seized
Jun 5th, 2006
  • Bronze, 100 points or more
Anything special for configuring a SBC T1 CAS Supertrunk? All six channels show seized intermittent. I have to call telco to have central office reset the channels. Happens 2-3 times a day.
BLW-2801#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxo-ls up dorm idle on-hook y
0/0/1 -- fxo-ls up dorm idle on-hook y
0/0/2 -- fxo-ls up dorm idle on-hook y
0/0/3 -- fxo-ls up dorm idle on-hook y
0/2/1:0 01 e&m-wnk up up seized idle y
0/2/1:0 02 e&m-wnk up up seized idle y
0/2/1:0 03 e&m-wnk up up seized idle y
0/2/1:0 04 e&m-wnk up up seized idle y
0/2/1:0 05 e&m-wnk up up seized idle y
0/2/1:0 06 e&m-wnk up up seized idle y
controller T1 0/2/1
framing esf
linecode b8zs
ds0-group 0 timeslots 1-6 type e&m-wink-start
description SUPERTRUNK
dial-peer voice 7075 voip
destination-pattern 70..
voice-class codec 1
voice-class h323 1
session target ipv4:10.168.32.12
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 210 pots
destination-pattern 9.T
port 0/2/1:0
Tommer Catlin Fri, 06/16/2006 - 14:52
  • Green, 3000 points or more
I had a problem the other night on my CMM where my CAS T1 line was showing 18 channels of the 24 "Pending"... it actually did not show pending until I "shut" "No shut" the port, then it popped up. I found some tech dock on Cisco's site to actually "reload" the whole card to get the channels to reset. Gateway reset in CCM would not do it. Reload only.
So you may want to try this and look at this fix
CSCef26431
Symptoms: Voice ports of a VIC-2E/M are stuck in "S_OPEN_PEND" state.
When you enter the shutdown command followed by the no shutdown command on
an affected voice port, the following message is displayed:
%C542-1-NO_RING_DESCRIPTORS: No more ring descriptors on recEive And
transMit 2/0/0. Msg id=26,Len=8^Z
Conditions: This symptom is observed intermittently on a Cisco 3745 that
runs Cisco IOS Release 12.3(9) and that functions as a gateway.
Workaround: Reload the Cisco gateway.
Jason Aarons Fri, 06/16/2006 - 17:03
My bug was CSCsc11833
Replaced the PVDM2-X; that fixed the issue. Apparently some bad PVDMs made it out of manufacturing.
