Warning message
FXO issues
Jun 5th, 2006
I current have a 2811 ISR installed in New Zealand with a dual ISDN wic and a vic2-2fxo wic. In Australia I have a 2821 with a NM-HDA 12 port FXS module.
If i dial the bri port on the 2811 the phone rings on the 2821 and the call completes correctly. If I dial the fxo port on the 2811 i get static on the phone and the call eventully timeouts.
I've adjusted cptone and impedence with no help.
Paul
voice-port 0/1/0
compand-type a-law
cptone NZ
connection plar 300
description isdn port 0
voice-port 0/1/1
compand-type a-law
cptone NZ
connection plar 300
description isdn port 1
voice-port 0/2/0
cptone NZ
impedance complex3
description fxo port 1
voice-port 0/2/1
cptone NZ
connection plar opx 333
impedance complex3
description fxo port 2
dial-peer voice 1000 pots
voice cut-through alert
description Incoming ISDN Dialpeer
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 1001 pots
direct-inward-dial
port 0/1/1
dial-peer voice 1002 pots
description Incoming Analog Dialpeer
direct-inward-dial
port 0/2/0
dial-peer voice 1003 pots
destination-pattern 0T
direct-inward-dial
port 0/2/1
dial-peer voice 3 voip
translation-profile outgoing calling
destination-pattern 333
session target ipv4:xxx.xxx.xxx.xxx
pacameron Sun, 06/11/2006 - 18:12
  • Silver, 250 points or more
Take the command 'direct-inward-dial' of dial-peer 1002 and 1003 - this is only used for PRI or BRI port types and is not needed on analogue port.
If this still does not help, post the SH VER and SH RUN from both routers so I can see if there is anything else in the configs that could be causing this.
pkrekelberg Wed, 06/14/2006 - 17:07
Thanks for your advise, and the issue has been fixed. It ended up being a crossed patch cable between the wall jack and the fxo port.
