Warning message
summary of networks
Jun 6th, 2006
Is it possible for me to summarize my networks 192.168.11.0, 192.168.12.0, 192.168.13.0 ? into 1 eigrp statement, can I advertise them as the 192.168.0.0 network ? would this advertise each class c network out though ?
Overall Rating: 3 (1 ratings)
gpulos Tue, 06/06/2006 - 03:21
  • Blue, 1500 points or more
yes, you could advertise 192.168.0.0/16 via eigrp.
this advertise all three networks you are talking of.
this could be manually summarized to 192.168.0.0/21
carl_townshend Tue, 06/06/2006 - 03:28
but would this not be advertising the /16 network ? I have other sites already on this !!
vladrac-ccna Tue, 06/06/2006 - 03:46
  • Silver, 250 points or more
Hello Carl,
there's no way to aggregate these routes in a single stamement without including other subnets.
The best you can do is:
192.168.11.0/24
192.168.12.0/23
HTH,
if it does, remember to rate this post.
Vlad
michael_davis@e... Wed, 06/07/2006 - 18:37
The best single aggregate you could use would be:
192.168.8.0/21
which would include the following range of addresses:
192.168.8.0 - 192.168.15.255
Let me know if this helps by rating the post.
Michael
vladrac-ccna Wed, 06/07/2006 - 18:45
But that would be too inclusive and could create routing issues, if 192.168.15.0/24 is on a different part of the network for instance.
Vlad
michael_davis@e... Thu, 06/08/2006 - 15:54
Absolutely, but it is the only way I can see to meet the original requirement.
