3560 FiberModule -> Mediaconverter
Answered Question
Jun 6th, 2006
Hi Guys
I have a problem were i am trying to have my 3560PoE switch connect to a media converter. I can't seem to have them talking with each other.
Setup: 3560 -> FiberPatchPanel->Mediaconverter-> 2950 (Without fiber)
Overall Rating: 5 (1 ratings)
gpulos Tue, 06/06/2006 - 04:55
  • Blue, 1500 points or more
verify the following if possible:
1) fiber cable to patchPanel is OK
2) mediaConverter to patchPanel is OK
3) cat 5 from mediaConverter to 2950 is OK (use crossOver if required)
4) patchPanel termination is OK
jimmi.hvidtfeld... Tue, 06/06/2006 - 04:58
All of the above is OK. The connection has worked before. Only difference is that there used to be a mediaconverter in both ends. Now we have purchased a switch with fiber and we would like to take down one of the converters.
thomuff Tue, 06/06/2006 - 05:01
gpulos hit the nail on the end.
Also, do you have media Converter on both ends. Are they the same model? Also, have you try locking down the port? Is this an indoor connection or outdoor connection?
jimmi.hvidtfeld... Tue, 06/06/2006 - 05:24
Hey
No, the issue is that we are trying to take down a mediaconverter and patch it throu the switch instead.
So there is only a media converter on one end, and it is not a Cisco :)
I have just realized that the fiber module for 3560 is only capable of running at 1000Mbit. It can't be set manually to 100Mbit. The converter is 100/100. Is this a problem?
thomuff Tue, 06/06/2006 - 09:06
I would say that is the problem. The GBIC do not run at 10/100. You are going to have to get another media converter or another GBIC to make this work.
Is it a GBIC?
