06-06-2006 08:36 AM - edited 03-03-2019 03:31 AM
I've got 4 3750's stacked and running IPBase IOS w/o Crypto. I want to upgrade these to an image that supports crypto. In the instructions it says to use a command similar to this: archive download-sw /leave-old-sw /reload tftp://host/c3750-ipbasek9-mz.122-25.SEB4.tar. However, I can only download the .bin file, should I use a different method for upgrading, or is the bin file sufficient? If I need to do this another way, will the other method push the image to the other three switches?
Simon
06-06-2006 08:54 AM
Not sure if this is the instruction that you have but it has a step by step procedure on upgrading IOS on 3750 in a Stack:
copy tftp is a valid way in upgrading just the bin file.
Please rate helpful posts.
06-06-2006 10:45 AM
Bosalaza,
Thanks, for the additional links. However, I don't see where I can download the tarball image, only the .bin. Will the copy tftp command upgrade the bin on all 4 switches?
Thanks again,
simon
06-06-2006 10:54 AM
yes, it should.
The tar file should be available through CCO at the download page for switches.
http://tools.cisco.com/support/downloads/go/MDFTree.x?butype=switches
You need CCO login id and password though.
06-06-2006 01:35 PM
you can load a tar onto your device if you have enough flash room.
the tar then needs to be 'expanded' to either extract all files or the specific files you need to work with. this will require even more flash space.
a search on CCO for this exact file comes up blank. does not exist. verify you have the correct spelling, etc. if this is the file name you need.
then use the cisco software search tool as follows:
06-14-2006 12:08 PM
I went to the same issue to find out that to use the archive CLI command you must use a .tar file. You can download a .tar file by selecting the "WITH WEB BASED DEVICE MANAGER" in the IOS image library.
Dominic
