cisco 2811
Jun 7th, 2006
is there any published cisco documents that details the number of Simultaneous call set up requests a cisco 2811 can handele any any one time down an e1 pipe, for example , if 15 call set up requests come down the line to the GW (which is MGCP) can the GW handle these and what are the response times?
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 06/07/2006 - 05:18
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dave,
Have a look at this doc that shows performance test results for all of the 2800 series ISR. Maybe this will help;
Test Results
The tests reported in this document were designed to stress-test the Cisco CME and the appropriate Cisco 2800 and 3800 Series Integrated Services Routers. Showing how many Busy Hour Call Completions (BHCC) with a full load of data were introduced into the router and how the router performed.
Test results with the Cisco CME on the Cisco 2811 Integrated Services Router
Testing 24-User Office
Cisco CME — configured for 24 IP phones
24 IP phones
Tested
Pass
Simultaneous call setup/teardown
24 IP phones (1044 BHCC)
Tested
Pass
Cisco Unity Express — configured with 24 mailboxes
24 mailboxes
Tested
Pass
Simultaneous voice mail and retrieval
4 connections
Tested
Pass
Incoming/outgoing PSTN calls
Tested
Pass
Fax — T.38
Tested
Pass
Cisco Business Communications Solution Verified Designs (Test Results Ver. 4)
Performance Test Cases
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_installation_guide_chapter09186a008054bc93.html#wp1017779
Hope this helps!
Rob
Please remember to rate helpful posts.....
