Delay in dynamic re-skilling taking effect
Jun 7th, 2006
I hope someone can help, we have a customer using IPCC Enterprise v7 and they are experiencing delays of up to 10 minutes for an agent who is dynamically re-skilled to take effect, one agent even took over 1 hour. If the agent logs out and logs back in the change is immeadiate, but this is not practical in a busy environment. Any help/suggestions would be appreciated.
Rgds,
Rob Hearn
JAMIP
Zin.Karzazi Wed, 06/07/2006 - 06:00
  • Silver, 250 points or more
10min seems too much, In the Bug CSCsd75129 they stated 10sec:
Symptom:
using Dynamic re-skilling Tool on IPCC system.
If skills are changed for an agent in READY state using the Dynamic reskilling tool, there is 10 second delay before and calls are routed to that agent. This applies when skills are added or skills are removed.
If skills are changed for an agent in NOT_READY state and the agent becomes READY within 10 seconds, calls are routed immediately.
Conditions:
Dynamic re-skilling agent in READY state.
Workaround:
none
or check this link:
http://www.cisco.com/en/US/customer/products/sw/custcosw/ps1001/products_tech_note09186a008020b212.shtml
But you d better open a TAC case.
Karzazi
Please rate all helpful posts
