Warning message
SNMP for 6608 active calls
beth-martin Tue, 06/13/2006 - 06:57
  • Bronze, 100 points or more
There are no separate MIB modules defined for the 6608 card. However, if you want to see the number of completed calls from Call Manager, you can use the performance monitor counters. To view the number of completed calls, start up performance counters, added a new counter, select "Cisco MGCP PRI Device" under Performance object. One of the counters is "CallsCompleted". This should show you what you're looking for. For more information, visit
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c4cd1.html#36551 .
