06-08-2006 12:17 AM
Hi all,
Sometimes I get the alert notification 'HighDiscardRate'. When I have a look at the details of the alert I see that, for example, InputPacketRate is 1,7865E7 and the discard packets is the 99,9986%. It's is absolutely imposible this amount of traffic running.
This alert appears in 2950 switches (Gi interfaces) and it's cleared inmediately.
Does anybody know why it happens?
Thanks a lot
06-08-2006 01:41 AM
I'd say some counter in snmp going to its max value and then rolling over.
Might be due to software version on the device.
Cheers,
Michel
06-08-2006 03:24 AM
Thanks Michel
06-08-2006 05:54 AM
If you poll ifInDiscards and ifOutDiscards on the device via snmp are you still seeing results like this? That would help determine if its an IOS or application issue.
