Warning message
Equivalent Command for "sh top"
Answered Question
Hi ,
whats the equivalent of "sh top'(which runs in CatOS) command in IOS , is it Sh interface x/y ??
regards
Neo
Correct Answer by vladrac-ccna about 11 years 2 months ago
Hello Neo,
you could try "show interface summary" its not 100% the same, but its helpful.
HTH,
if it does, please rate this post.
vlad
switch-ud-2a>show interfaces summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
Vlan1 0 0 0 0 0 0 0 0 0
Vlan99 0 0 0 0 0 0 0 0 0
* Vlan164 0 0 0 0 0 0 0 0 0
* Vlan165 0 0 0 0 0 0 0 0 0
* Vlan166 0 0 0 0 0 0 261000 167 0
Vlan167 0 0 0 0 0 0 0 0 0
* Vlan168 0 0 0 0 0 0 0 0 0
* Vlan169 0 0 0 0 0 0 0 0 0
* Vlan170 0 0 0 0 0 0 0 0 0
* Vlan171 0 0 0 0 452000 313 119000 101 0
* Vlan172 0 0 0 0 0 0 0 0 0
Overall Rating: 4.5 (2 ratings)
Correct Answer
vladrac-ccna Thu, 06/08/2006 - 03:17
  • Silver, 250 points or more
Hello Neo,
HTH,
vlad
*: interface is up
devang_etcom Thu, 06/08/2006 - 05:38
  • Gold, 750 points or more
thanks Vlad i also get some information fromm this
will you give me some information regarding to catos and IOS???
hereby i rate your post and congratulation to get silverstar.
regards
Devang
glen.grant Thu, 06/08/2006 - 03:46
  • Purple, 4500 points or more
As far as I know there is no real equivalent for the show top which is a basically timed report of whats happened for say the last 15 minutes . For traffic counters you can use "show interface counters" , for error type traffic you can use "show interface counters errors" .
