Warning message
PIX with very strange DHCP behavour
Jun 8th, 2006
all clients asking for an IP address (via dhcp) get an address starting at 129.168.0.128 and up. i havent made any such configuration on the pix though. the DHCP pool we made is IPs in the range 192.168.1.50-100 (and 192.168.1.150-170 for VPN users). there is no other DHCP server on the network, ive even tried unplugging everything short of one pc directly on the PIX LAN interface. there is nothing in my configuration that use this 192.168.0.x addresses and when i do a "ipconfig /renew" i get 192.168.0.128.
dhcpd address 192.168.1.50-192.168.1.100 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
thoughts?
Fernando_Meza Thu, 06/08/2006 - 16:49
  • Gold, 750 points or more
It sound like a bug ... what version of PIX are yu running .. also when you get IP address which is the DHCP server that shows up whne you type in ipconfig /all
thomassadi Fri, 06/09/2006 - 03:17
hi, thanks for your reply.
PIX Version 6.3(5)
The default gateway is 192.168.0.2 and im not able to ping that address.
