Warning message
what happened when I enter the command "distributed-list"
Jun 9th, 2006
Which table on the router or switch will be modified after I use "distributed-list" to filtering routing.
If I just apply this command to special interface, what happened?
thanks.
sun
devang_etcom Fri, 06/09/2006 - 02:05
  • Gold, 750 points or more
distribute-list in (IP) Filters networks received in updates.
distribute-list out (IP) Suppresses networks from being advertised in updates.
distribute-list commands are used for the influancing the routing update...you can filter or allow the perticular update in you network
regards
Devang
