Warning message
virtual-profile aaa again: i'm puzzled
Jun 9th, 2006
I am trying to get a dialup config to work that uses virtual profiles by virtual template and AAA configuration. When I follow the Config guides (12.2 in my case) I am told to use the command virtual-profile aaa. This command does not seem to exist in IOS anymore (or is always on as another NETPRO post by Glenn Fullager states).
My dialup connections cannot bind the IP address that is presented to the NAS by the radius server to PPP. Debug aaa per-user does not give one line of output. Am I missing a command or does somebody have an idea where I go wrong?
see attached config
Mat
globalnettech Mon, 06/12/2006 - 00:59
  • Silver, 250 points or more
which IOS feature set are you using (and on which platform) ? The config should indeed look like this:
virtual-profile if-needed
virtual-profile virtual-template 1
virtual-profile aaa
interface Virtual-Template1
ip unnumbered FastEthernet0/0
no ip directed-broadcast
no keepalive
ppp authentication chap
ppp multilink
Can you try and configure a local pool and see if you get this to work ?
GNT
