Downgrading WLSE
Jun 9th, 2006
If I bought the current WLSE product (CWWLSE-1133-K9), this comes with software 2.13. Would it be possible to downgrade the software to 2.7.1, which is what I have tested and certified?
rmushtaq Fri, 06/09/2006 - 11:48
  • Blue, 1500 points or more
Downgrade can only be done using the Recovery CD for 2.7. But going from 2.13->2.7, you will loose lot of features/functionality/bug fixes which are available in 2.13
Trending Topics - Security & Network
