Warning message
Create .csv for bulk import
Jun 9th, 2006
I'm having trouble creating a .csv for bulk import into Common Services of Ciscoworks. What is the easiest way? I keep getting "Invalid file format" when I use a .csv created from excel
Overall Rating: 4.5 (2 ratings)
nhabib Fri, 06/09/2006 - 10:58
  • Red, 2250 points or more
The easiest method is to export to file first and then use wordpad to add more entries. Save as text file (no special formatting).
nhabib Fri, 06/09/2006 - 11:32
Add one device to CiscoWorks manually, and then export from CiscoWorks. This will provide a file with the proper format.
