RTP compression query
Jun 11th, 2006
Hi all,
Router(config)# interface Serial1/0.0
Router(config-if)# encapsulation ppp
Router(config-if)# ip rtp header-compression
Router(config-if)# ip rtp compression-connections 150
For the command "ip rtp compression-connections 150", is there any relationship with number of voice channels? If so, how many voice channels can support and what if it is exceeded 150?
mak
Overall Rating: 5 (1 ratings)
anup.anand Sun, 06/11/2006 - 20:45
  • Silver, 250 points or more
Each connection corresponds to a RTP stream, equivalent to a voice channels. So you should get 150 voice channels. If it exceeds, then the rest of the RTP Stream will be send uncompressed. This can oversubscriber the link and affect the quality of all calls.
Anup
