Warning message
Async callback-line
Jun 11th, 2006
Has anyone had success using the callback-line or callback-rotary async config commands?
I'm trying to configure a router to perform call back using a specified line. But it seems to ignore the callback-line command and always call on the same line the user dialed in with, or the next available line...
waqas.ashraf Tue, 06/13/2006 - 01:55
I have worked with the help of the following command on a clients machine and they did not complain, so i believe that it worked. send us your config and we can have a look at it.
username name [callback-line [tty] line-number [ending-line-number]]
Please rate, if it helps.
Regards.
