Warning message
Subscribers AD Accounts not visible
Jun 12th, 2006
I am running Unity 4.2.1 VMO system with External Exchange. The Exchange server is the Domain Controller.
My problem is that all the imported subscribers' AD accounts are not visible in ADUC unless I do a find. Basically, if I open ADUC and click on the Users container, I see everything except the imported users. However, if I right click on the Users container and do a Find, I can find and access any of the subscriber accounts.
Input from anyone with suggestions is appreciated.
Thanks in advance!
Robert
Tommer Catlin Wed, 06/14/2006 - 13:07
  • Green, 3000 points or more
If you just imported them from the CSV import on Unity, it will take AD a little bit to "catch up" The SQL database has to sync with the AD directory. Once this is complete, everything should be visiable.
Also remember, when you import users from a CSV with th e the Unity interface, Unity does not create the "Display Name" how an AD administrator would create. The Display Name in the ADUC is the Exchange Alias. So you were searching for John Smith, you probably seach for jsmith if you did first initial last name.
You may also have a large AD enviroment with site connectors. Accounts may take a while to generate between the sites, etc.
Hope this helps.
tc
ROBERT SCHAUFLER Thu, 06/15/2006 - 08:17
TC,
Thanks for the input.
The users have been imported for some time and do show up in AD, its just that I have to "find" them to view their properties. The environment is relatively small with only a few hundred users in a VMO system and their are no site connectors configured.
I have discovered a couple of additional items which may shed some light, however. 1) If the users are created in Unity SA they appear normally in ADUC by simply clicking on the "Users" container. The issue is only with users who were bulk imported 2) If I choose the option to View "Advanced properties" in ADUC before clicking the Users container I am able to view all the user objects as I normally would.
-Robert
Tommer Catlin Thu, 06/15/2006 - 08:26
It sounds like a Windows Server issue to me. I have seen this before somewhere.. but I can't recall what it was to fix it..... it's nothing to do with Unity.
Try this:
Since you are running VMO... you may only have one server with Unity/DC/Exchange all on one server. IF you have another server and are a "windows" person... run the snapin for ADUC on another computer and see if you can access the same information, but from another server
Server B: in the VMO domain.
Click Start
Run
type in MMC
File Add/remove snapin
Users and Computers.
As long as you are logged in as Admin... you should be able to read/write to the domain from a member server with the MMC snapin. This will at least tell you if it's on that one server or a domain problem.
And if you havent restarted Unity yet... I would probably reboot to see if it fixes the issue. (easy first I guess)
Ginger Dillon Thu, 06/15/2006 - 10:34
  • Blue, 1500 points or more
Hi -
Do you have Exchange System Manager running on the Unity server? Or are you using ADUC from Programs - Administrative Tools. If you don't have ESM on the Unity box, install that and then see if your ADUC functions differently.
Ginger
