Warning message
Cisco ASA and auth
Overall Rating: 3.7 (6 ratings)
devang_etcom Tue, 06/13/2006 - 06:17
  • Gold, 750 points or more
when you are using the local database for authentication then router will search its database...but when ever you are haivng externeal server then you have to configure the router to forward the new connection or incomming connection requrest to the external host or server who is having authentication AAA database...so here you need to configure the router to forward the request to that server and server will prompt for the username and passwords
hope this will help you
rate this post if it helps
regards
Devang
tdrais Tue, 06/13/2006 - 06:51
  • Blue, 1500 points or more
I do not have a lot of experence with the ASA but if its like most other cisco products they do not support windows AD directly.
You can use a radius or tacacs server which can then use the AD server. You should be able to run the radius or tacacs server function on your AD server if you like since there are many avaiable for windows.
tdrais Tue, 06/13/2006 - 07:48
Looks like I need to go study the aaa in the ASA boxes if they now take NT domain as a option.
The authorization is normally what commands a user may issue after he has logon the router. It is allows more contolled access by user rather than changing the commands themselves into other access levels and using enable levels for control. I do not think this is used in a VPN environment but they may have changed that also since the ASA boxes came out.
devang_etcom Tue, 06/13/2006 - 07:58
it means its provide the authentication to users...
normally in security we are assigning some specific task or application to the perticular user with the help of the authentication and authorisation...
authentication will tell the user is reliable and authorisation will tell the user have XYZ privillages to access...means here there is a entry with user name, password as well as the privillages level...so this is what the difference between both.
regards
Devang
devang_etcom Tue, 06/13/2006 - 08:54
here RADIUS LDAP OR TACACS will also provide you the all authentication, authoirsation and accounting ...
here are the few links which will help you...
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080094e99.shtml
RADIUS: http://www.cisco.com/en/US/tech/tk583/tk547/tsd_technology_support_sub-protocol_home.html
TACACS:http://www.cisco.com/en/US/tech/tk583/tk642/tsd_technology_support_sub-protocol_home.html
ASA:http://www.cisco.com/en/US/products/sw/secursw/ps2086/tsd_products_support_series_home.html
here you have to do some reading work but it will be help full to you
regards
Devang
dbakula01 Tue, 06/13/2006 - 09:07
On any windows server 2003 at least, you can install IAS or Internet Authentication Service under the add/remove windows components of the networking services section. It's a microsoft radius server.
then on your asa put it's IP as the aaa server. Its actually really easy
devang_etcom Tue, 06/13/2006 - 09:15
yes it is...you can find radius on window 2003 server by
start- administrative tool-routing and remote access then right click on property ...then select security tab and then select RADIUS authentication...
and you can have RADIUS for Linux also on i think www.freeradius.org...
its very easy to configure...
regards
Devang
