Warning message
Unable to NAT properly with 850 router
I am new to using the 850 router and having some issues with NAT working while also setting up my SITE-to-site vpn.
I have used this config on my 831 routers with no issues but I am not able to communicate out from the inside at all. No traffic accross tunnels or to internet
Can anyone see what I am missing?
I have atteched my config.
Thank You!
Overall Rating: 4 (1 ratings)
mheusinger Tue, 06/13/2006 - 08:16
  • Green, 3000 points or more
the config contains "no ip routing", which turns off routing of IP packets. Thus you can not forward IP packets towards the Internet. Also CEF is turned off and usually the router has a better performance with CEF enabled. So please configure:
Router#conf t
Router(config)#ip routing
Router(config)#ip cef
Router(config)#end
Router#copy running-config startup-config
The rest does look not too bad, so lets start from enabling routing and then work from there.
Hope this helps! Please rate all posts.
Regards, Martin
