7936 - 2 Callesr Dial in, Conference them together
Jun 14th, 2006
Hello, I'm having an issue and wondering if it's by design or actually a bug.
So, if we have a 7936 conference phone. An outside caller dials the conference phone number, we answer it just fine. Another outside caller also dials the confernece phone number, we answer it, the first caller goes on hold and we can speak to the second caller.
Now, we want to join the conference phone, with the first and second caller into one conference call. We go to menu, caller options, join, and nothing happens, the display just goes to the main window. One caller stays on hold, the other caller is active.
The join feature does not work on the 7936, however, the same process does work with our other ip phones (7912, 7941, 7961 and 7970's).
I'm I missing something here?
Thanks Ash
gpulos Wed, 06/14/2006 - 09:49
  • Blue, 1500 points or more
are you able to have both calls on line, then use the SELECT button to select one of the calls, then scroll to the other call and press the JOIN button?
can't join two calls unless they're selected or at least one of them selected, then scroll to the other call and press JOIN.
Rob Huffman Wed, 06/14/2006 - 09:51
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ash,
Maybe you are hitting this bug;
CSCef12306 Bug Details
7936/7935 conference stations do not support JOIN feature of CCM 4.0.
First Fixed-in Version 4.1(2)ES21, 4.0(02a)ES29, 3.3(5)ES05, 3.3(4)ES50, 3.3(3)ES77, 3.3(5)SR01a, 5.0(1.050.115), 5.0(1.050.124), 5.0(1.1000.002), 5.0(1.099.033)
From this doc;
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCef12306&Submit=Search
Check out the fixed in version's
Hope this helps!
Rob
Please remember to rate helpful posts.......
abaulackey Wed, 06/14/2006 - 11:42
Thanks Rob
So we have 4.1(3)sr 3a, what this tells me is they fixed it in 4.1(2), but removed the fix for newer releases?
Rob Huffman Thu, 06/15/2006 - 06:48
  • Hall of Fame,
    Founding Member
Hi Ash,
The fixes should be cumulative, so the fixed in version showing 4.1.2 should carry over to 4.1.3sr3.
I looked into this a little further and noticed that this bug is actually associated with the 7935/7936 phone firmware and has been there since at least the 3.0.9 version and carries through the 3.0.10 and into the newest 3.0.11 7936 firmware.If you check out the "Read-me" for 3.0.11 it still shows this "Join" feature not working as an open Bug.
Perhaps you should contact TAC to see if this is actually fixed.
Hope this helps!
Rob
abaulackey Thu, 06/15/2006 - 09:21
Thanks for checking into this Rob, I'll contact TAC.
